Would like to take a captured AVI or MPEG2, or home movie and convert it to VOB, IFO, BUF files (DVD Decrypter type files). This way I can use dvd shrink to make it fit on one DVD (of course less than 4.3GB and less than 120min).
OR
Is there a good (simple) way of compressing the AVI so that it will fit onto 1 DVD?
I hope this is on the right part of this forum ~ my first post.
Thanks to all that help![]()
Help is always appreciated.
VOB, IFO, and BUP files are standard files found on any authored DVD. Just encode your video to a DVD-compliant stream with MP2 or PCM or AC3 audio. Use any standard authoring program to put in menus, chapters, etc. THEN BURN IT! I recommend using TMPGEnc DVD Author or DVD-Lab, cuz they're the kewlest/most flexible.
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 07:04 -
Differences between converting from ifo/vob to avi
By redhot in forum DVD RippingReplies: 2Last Post: 13th Dec 2008, 11:57 -
VOB IFO and VOB, clueless need expert help :)
By Skunk141 in forum Authoring (DVD)Replies: 5Last Post: 13th Dec 2007, 16:03 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 13:10
