When I load MPEG-2 files into Windows Media Player they have bad interlacing, and some green blocks at the bottom of the file. So far I have tired the K-lite codec pack (which did nothing) power dvd (which did nothing) and the intervideo mpeg-2 codecs.
The Intervideo winDVD codec pack fixed the problem, but after it was installed, loading files (whether they were mpeg-2 or not) took a very long time to load (and that was unnacceptable)
Anyone who knows of any other mepg-2 codecs, or knows what possible codec conflict could have caused the extremely long load time with intervideo installed please respond.
-Heflink
I've had huge problems with Elecard. That thing is worse than bubonic plague. Kill it if you find it. I use Ligos on my system. Use PowerDVD to watch the files deinterlaced, not WMP9.
Yah, I really would like to get things to work properly with WMP though, im not a big fan of running things through powerDVD/ winDVD..
Thanks for the suggestion though. -
Originally Posted by Heflink
I figure that my problem with winDVD is a codec conflict, does anyone know how I can disable the previous codecs (like the default ones with winXP).
Or am I stupid for thinking that that is why I took so long to open a file.
-Heflink
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
WMP9 Plays M2TS BlueRay
By wulf109 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2008, 19:10 -
Playing "FLV4/VP62" via WMP9 /GSpot? (No Video)
By j_hallgren in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2008, 10:25 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24 -
want to play VTS_01_0.IFO with wmp9 under win2k
By vobnovice in forum Software PlayingReplies: 3Last Post: 7th Jun 2007, 12:31
