I'VE HAVE LOOKED EVERYWHERE AND CAN'T FIND A STEP BY STEP PROCESS ON HOW TO DEMUX A VOB FILE INTO A M2V AND AC3 FILE, EDIT THE AC3 FILE AND REMUX THEM BACK TOGETHER TO FORM A VOB FILE READY TO AUTHOR TO A DVD. MAYBE IT CAN'T BE DONE ALL I'VE SEEN IS PARTIAL METHODS AND THEY AREN'T SURE. BEING A NOVICE AT
DVD AUTHORING I WOULD LIKE TO FIND A YES OR NO ANSWER IF POSSIBLE. I CAN DO IT PERFECTLY IN .VCD FORMAT BUT HAVEN'T BEEN SUCCESSFUL IN DVD. IF ANYONE KNOWS HOW PLEASE GIVE A STEP BY STEP METHOD ON ACCOMPLISHING THIS, IF I SOUND BLUNT IT IS JUST HARD TO FIND THIS OUT, A BIG THANKS FOR ANYONE WHO CAN TELL ME AND MANY OTHERS FROM WHAT I'VE READ ON FORUMS HOW TO DO THIS FEAT.![]()
www.dvdrhelp.com/faq#demultiplex to mpv and ac3
I don't know any ac3 audio editor
To multiplex back to a vob you should author it, www.dvdrhelp.com/author#dvd or just multiplex back to basic mpg with ac3(you could name it vob), www.dvdrhelp.com/faq#multiplex -
SmartRipper will process the remuxing step. yhen you need a AC3 ro Wav convertor, a WAV editor and a WAV to AC3 to convertor.
the muxing with produce a MPG file. VOB are from DVD author programs. Yo convert a MPG yo a VOB, create a DVD and use the VOB you want from it. -
Baldrick !
Could you explain in more detail how you multiplex the video xxx.m2v
and the audio xxx.ac3 to a MPEG stream, because TMPGEnc does not fix it.
I do not want to convert the AC3 sound to wave or another format
