This has happened to me for a few verbatim CDRWs, after 2 mnths or so
And I am wandering if I can avoid this in future .or is there a better software
I use Roxio direct CD version 5
I have at least 3000 word documents, 600 folders in 1 CDRW ..
On a daily basis , I will write and over-ride 100 files per day i.e. open up the file , add new info and save it again )
1) When I insert this CDRW into a different CD ROM drive to read , the following will happen when I put back the same CDRW back to my original CDRW drive ,
a) the CDRW would not be able to perform as a CDRW , but the whole disc would be a Read only CD , ( means all files can be re-written anymore)
b) There will be a direct CD 5.1e3c error saying that requested files cannot be read from CD , IT is recommended to copy any critical files to a new CD
c) Sometimes , when you re-insert the disc again into the same CDRW drive , the following error will occur .
1) I can read the label , but cannot see the files at all
2) I will be prompted to reformat the disc ,( free space 0 , Total space .2.2 Gb
I would suspect your disc may be wearing out. I've had some CD-RWs formatted for DirectCD develop the same problem.
I'm defnintely not an Orange Book Part III genius, but I suspect everytime you update a file, the Table of Contents has to be rewritten, and it's in that area where the phase-change alloy is wearing out. I suspect that is why you sometimes cannot see the contents of the disc.
Of course, I could be wrong...
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 22:53 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
Problem playing DVD-R in several CDRW/DVD
By shortytigg in forum Authoring (DVD)Replies: 7Last Post: 20th Feb 2009, 14:39 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 21:35
