Hey, I just did a quick scan here, and have seen a lot of I like this, that sucks etc.
I am also kind of new to this aspect of computers.
I am looking to get a capture card of some sort, preferably one that captures at a high enough resolution, when I put it on VCD or DVD and play it back on my TV it looks good.
I have seen a few say they like the TV Wonder, and it is cheap enough, but I cannot find one reference to it's capture resolution or frames per second.
Or should I be looking at a different product?
my system for this is going to be either my Dual Athlon 1.2's with 1 gb ram, or a 1.33ghz. OC'd to 1.53ghz.
Both systems have GeForce 2 Ultra cards, and both have 10k rpm SCSI hard drives, 36.4gb striped.
I will be using svideo or RCA out from my TV for UPN shows, and Svideo out from my DirecTV box for everything else. I'l be dumping video out to my Pioneer DVR-A03.
Any advice?
i have the tv wonder ve. i like it and capture from dish network. my results after hundreds of tests are a little better than vhs with about 40 min on a cdr. only negative complaint i have against it is that there is NO S-Video for it. cable and RCA jacks in it for video and sound must go into the sound cards line in jack....i'll probably end up looking for an upgrade in the future so i can have the S-Video.....picture quality is all that makes it worthwhile for me...
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
