Hi, I could use some recommendations... I've been trying to create an svcd out of my wedding video, but while I can handle the authoring part so-so, the problem is the capturing. Previously the problem was that my WinTV card only allowed me to capture video @ 320x240, which looked shitty when blown up to 480x480. I posted here about it and someone suggested I get the hacked drivers for the bt878 card, and yeah, it works just fine, now I can capture at any res I please. However, when I capture at 640x480, I seem to keep getting a lot of dropped frames, as the end result video has little twitches now and then and the sound breaks up during those twitches. I am wondering if there is anything I can do to help this? I have been capturing the video uncompressed, straight to AVI with no compression. Is there a reasonable alternative? Capturing 320x240 to uncompressed AVI was bad enough, hard drive space -wise, but 640x480 really takes a lot of space...we're only talking about like 25 minutes of video, so....
Any suggestions would be most welcome.
I use WinTV with Adobe Premiere to capture, the system's a Dell 4400 (P4 @ 1.6 GHz) with about 400 megs of RAM and 45 gigs of HD.
try capturing with Huffyuv compression - it's really light, but is definitely smaller than uncompressed, and gives me really good quality.
you can also try MJPEG compression at quality setting 18 or 19 (out of 20) - seems to be the most popular Huffy alternative for high-quality avi capture.
if your capture software won't let you choose those codecs after you install them, get more robust capture app! VirtualDub is super popular (and free!), my card doesn't like it, so I've used Virtual VCR (freeware) and iuVCR (cheap).
but you are using premiere, so you shouldn't have a problem. you might try another capture app anyway, any of the ones I suggested will be leaner than premiere, so that might free up some system overhead that premiere is using (aside from the resources it's using to capture).- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 06:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 14:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 09:49 -
Which Codec is the Best for Capturing?
By rocknico100 in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 20:47 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 11:40
