Hi guys,
Was wondering whether it would be possible to use CSS Lock with VCD. I was thinking maybe if we made a simple menu on the VCD, maybe we could use CSS lock or some sort of copy protection on it.
Haved been able to lock the VCD from duplicators but it doesn't stop pirates from copying it through proper CD replication.
I know even CSS lock is easily cracked by many softwares for DVD's but was just wondering whether it could be done on VCD.
Thanks in advance guys.
can't be done w/ VCD and can't be turn w/ consumer DVD burners either.
VCDs don't support CSS protection, or any other formalized type of copy protection. There are certain little tricks you can use to make copying more frustrating, but they are ultimately very easy to get around. Sorry, there isn't much you can do.
As above.
VCDs don't support CSS.
In fact, your consumer DVD burner doesn't support writing it either.
If you really want to frustrate potential copiers, some like this: http://www.vcdimager.org/guides/combination_lock.html might be your best bet.
Regards.Michael Tam
w: Morsels of Evidence
CSS : Confusing as ever...help??
By beavereater in forum ComputerReplies: 2Last Post: 8th Jun 2011, 01:25 -
How to tell if Disc has CSS and/or Macrovision?
By videopoo in forum DVD RippingReplies: 1Last Post: 22nd Oct 2010, 14:01 -
how to remove css protection from dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2008, 20:28 -
CSS
By romanstopme in forum Off topicReplies: 1Last Post: 2nd Jun 2008, 23:58 -
Add CSS to DVD's
By Jerk in forum Newbie / General discussionsReplies: 18Last Post: 16th Jul 2007, 04:23
