I am interested in buying a particular region 2 and/or 4 DVD. Just got into this whole DVD ripping thing, if I bought this DVD, could I rip it and copy it to a blank DVD+R and play it in my Region 1 DVD player?
Thanks.
"Wanting people to listen, you can't just tap them on the shoulder anymore.
You have to hit them with a sledgehammer,
and then you'll notice you've got their strict attention."
-John Doe in Se7en -
Yes and no. Yes you can rip it (the region only refers to playing not ripping). But correct me if I'm wrong but region 2 is Europe which = PAL. So you can't just burn and play that on most USA players (which are NTSC).
Some players (eg. cyberhome) will do a PAL to NTSC converison on the fly for you, but most will not. Do a forum search for PAL to NTSC, but what seems to work the best/easiest is to:
https://www.videohelp.com/forum/viewtopic.php?t=166720
1) Rip DVD the full DVD to HD (smartripper choose backup, or in DVD Decrypter choose 'Mode | File' then select all files)
2) Open the VIDEO_TS.IFO in IFOEdit. Click 'make region free' and let it do it's thing.
3) Scan the EVERY IFO file for where is says PAL, double click on that line and change it to NTSC (header trick, this actually seems to work).
4) Burn the VIDEO_TS folder as normal -
Thanks for the tips.....!!!
-John Doe in Se7en
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 04:35 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
DVD is only available from Australia (PAL)- can I rip it and make a copy?
By stoker in forum MacReplies: 6Last Post: 22nd Sep 2010, 23:11 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
