I'd like to know if you can use any avi codec with this card (e.g. HuffYUV or MJPEG). I don't care much for MPEG-1/2 capture.
And is the card flexible when it comes to setting the capture resolution or does it limit the user to a few resolutions?
Also, if someone has the PAL version of the card, does it have some sort of PAL-60 mode to capture NTSC material played back on a PAL VCR?
Yes you can use other third party software such as Morgan Multimedia MJPEG and HuffYUV to capture AVI with this card.
This card is able to capture video using standard resolutions such as 352*240 (NTSC), 352*288 (PAL), 640*480, 720*480 (NTSC) and 720*576 (PAL). If you intend to capture video using resolution that is higher than 352*288 then you may want to stick using its bundled WinPVR software, since I've never been able to do so using other video capture software such as VirtualDub.
I do have the PAL version of this card. I have never captured AVI from any NTSC video that is played back on PAL VCR, but I did capture videos from other direct NTSC sources using 350*240 and 720*480 resolutions. -
What you can do is select uncompressed AVI, select configuration select your resolution and compression and add that as a new configuration. Then you sould be able to capture AVI with HuffYUV compression.Originally Posted by mic_
BTW this card is limited to predefined set of resolutions.
Hope this helps
Dominic
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
