Hi all,
I am converting my mom's old work out videos from VHS to DVD. My process gives good results on everything except one stupid video, it produces a big white/grey band through the image from beginning to end. I would assume this is some kind of copy protection, but since I'm backing up an original can someone please tell me the cheapest fastest way to remove this. Thanks a lot!
rhuala
ps. Capturing with MSI Gf4 Ti4400 and Virtual VCR
Tommyknocker,
The band does NOT appear on the TV only on my .avi captured file upon playback.
rhuala -
Do you use Virtual Dub to capture? If so, in the preview mode, does the band show, and can tracking adjust the position of the band, and where does the band appear on the screen?
Hello. -
I use Virtual VCR for capturing and MSI Gf4 Ti4400 card (Can't get good results capturing with Virtualdub on WinXP with the WDM wrapper). Anyways on previewing the capture with Virtaul VCR the band does NOT appear. Thanks for your help so far Tommyknocker, I appreciate it....
rhuala -
By the way for anyone else that may have this problem or run across this thread in a future search, the way to get rid of it is to re-install WMD drivers version 1.08. I had the latest 1.16, once I removed them and tracked down the old version the lines went away. That was the only thing I changed so I am positive about this solution (no guessing here). If you want the old drivers PM me and I'll email them to you.
rhuala
PAL Capture Black & White
By SGGS in forum Capturing and VCRReplies: 42Last Post: 9th Dec 2011, 05:12 -
Black & White Capture w/ Dazzle!
By Rowan88 in forum Capturing and VCRReplies: 9Last Post: 12th Mar 2010, 14:42 -
horizontal white scratches - VHS capture
By Scott L in forum RestorationReplies: 7Last Post: 29th Jun 2008, 23:07 -
Capture Card,Black and White
By I STANFORD I in forum Capturing and VCRReplies: 8Last Post: 28th Jun 2008, 11:26 -
video capture in black and white only
By oldboy29 in forum Capturing and VCRReplies: 8Last Post: 13th Jan 2008, 18:54
