  1. I just burned an XVCD by folloing the guide, and burned it with Nero, when I play it on my Toshiba SD 2800, there is no picture, the audio is there but no picture.
    Could this be because of the video resolution? I think i selected 720*480 as recommended in the guide, but it also said "if it works with your player" how do i find out what resolutions my player can support?
    Apr 2002
    The State of Frustration
    You are not looking for a particular resolution, you are looking in the DVD database for your player vs. XVCD (CD-R). Had you completed the Computer Details section, I could have done it for you.
    Hello.
  3. I thought that SD 2800 is compatible with XVCD. What information are you looking for in terms of computer details? I use 2 diff machines both laptops, some of the information I dont even know but let me know and I can find out and post.
    Apr 2002
    It may be Nero. Have you tried to burn it with VCDEasy?
    Hello.
  5. Originally Posted by Tommyknocker
    No, have not tried that yet, I was merely following the guide, still a newbie when it comes to conversion. If something goes wrong than what is mentioned in the guide, I am clueless as to how to fix it.
  6. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Yes. You need to keep your resolution set to 352 x 240, but up your bit rate. I own a Toshiba SD2800 and I'm able to play XVCDs burned with either Nero or VCDEasy. I've used TMPGEnc Plus to encode at 352 x 240 with bit rates up to 5000 kbps. I successfully played XVCDs authored with VCDEasy, Dazzle DVDComplete and Ulead Movie Factory.
    Early on when experimenting with XVCDs, and using CD-RWs, I tried different combinations of resolution and bit rates. I found that anything with a resolution different from 352 x 240 would not play correctly.
  7. Thanks a lot, that solves a lot of problems. I am going to buy some CD-RW's and experiment with other resolutions, if they don't work, gona go back to what you mentioned. Good to know that it supports Xvcd's, can't wait to burn one tonight.
