I used VitualDub 1.5.4 to extract the WAV file from a DIVX file. The WAV file has a background hiss. What's the best way to remove the hiss? FYI, I have used GoldWave in the past - does it have this functionality?
Noise Reduction
Use shape
Lets you manually create an envelope shape or select a preset shape. See Shape Controls
for information about creating shapes. By setting a horizontal line at about 75 dB, you can remove a hiss from a sound.Hello.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Is There a Free Program that Removes Hiss and Pops from WAV files?
By cplevel42 in forum AudioReplies: 10Last Post: 24th Nov 2009, 13:28 -
'S' letter hiss (deessing) - how to separate 'S' frequencies in a WAV?
By zee944 in forum AudioReplies: 2Last Post: 28th Nov 2008, 12:32 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 06:18
