hi .is their a way of splitting a dvd cover using just halve of it. then using a authoring soft ware, to add menu or chapter points on top.if so can anyone point me in the right direction thanxs.
if you save just the part of the cover that you want to use as a jpeg or bitmap. Programs such as DVDITpe and DVD-Lab will let you import that file to be used as a menu background.
thanxs for looking.what software would i use to extract only just halve of the cover.as i havnt got any photo software yet. can anybody suggest one thanxs
Paintshop Pro is a good solution for your needs. Not very expensive and does a good job.
http://www.jasc.com
Album covers
By ssaamm in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2011, 06:38 -
printing covers?
By zoobie in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 20:40 -
DVD covers
By Seasonal in forum Off topicReplies: 3Last Post: 3rd Mar 2008, 19:30 -
DVD Covers
By Beefer in forum MacReplies: 7Last Post: 15th Nov 2007, 15:17 -
HQ DVD Covers Before There Release
By twiggy99 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 15:01
