I have several music videos in .vob file that I want to convert to .m2v. Anyone help me with that?
TMPGEnc. Load the VOB as video input. Select Settings/MPEG-2. Voilą!
Hello. -
Correct me if I'm wrong, but wont that also re-encode the video? I dunno if this is what you want...
You could also just use TMpeg but go to MPEG Tools and do De-Multiplex, load up the VOB and save the m2v.
But now if I could ask a question myselft....
Doing TMPEG Demux works only with the VTS_01_1 file, and no subsequent VTS files. Why is this, even if the second one is exactly the same filesize, it doesn't work? Anyone know? -
Originally Posted by PhatslugHello.
If you want to demux these files to elementary streams (m2v and ac3/pcm respectively), I highly recommend ol' DVD Decrypter www.dvddecrypter.com. Simply put in the disc and fire up File Mode, right click the VOB you wish to demux on the side panel and select STREAM PROCESSING, then put a checkbox near the files you plan to use. For your video file, highlight it and make sure the DEMUX button is selected, then go to your audio source (PCM/AC3) and make sure DEMUX is also selected, then hit OK.
After you're done with that, double check your folder and presto! you should have your elementary streams (M2V and WAV) for your intended purposes. Hope this info helps you in making your music videos!
-freestyler
IVTC a vob/m2v file before FCP editing
By kmxe in forum MacReplies: 18Last Post: 18th Mar 2010, 02:15 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Need help converting an .MDS file into a .VOB file can anyone help??
By casper1910 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2009, 04:08 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
