Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. just to make sure i did everything rite---one more time funky
    1)I demuxed ac3
    2)I frameservd the .avi and encoded to mpeg2.
    3)Now i use the authoring software to put them together ?
    Is there a step between 2 and 3? am i suppose to do something with the .ac3 in besweet or is that only if the audio was .mp3 on the original .avi
  2. Originally Posted by PhoenixL
    1)I demuxed ac3
    No, no middle step, you've done just fine so far! Just use something like TMPGEnc DVD Author or DVD-Lab and load them up like they are!
    <read after trying the above apps>
    If you find that the video happens to be slower than the audio, you most likely forgot to tell TMPGEnc to include the 3:2 pulldown flags when you encoded. In this case, just IM me or PM me and I'll send you a free and legal program that will insert the flags for you and I will help you set it up correctly so you don't mess up your MPEG video file.
    </read after trying the above apps>
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
  3. ok im pretty sure i put the flag
  4. Originally Posted by PhoenixL
    Was it too slow?
  5. dont know yet , i tried on dvd lab but it says that it has to be elementary? or am i doing it wrong. i;ll keep tryin and get back to u.
  6. Originally Posted by PhoenixL
    you proabably encoded it as a system (video only). Just use TMPGEnc Meg tools simple demux, and that will give u an elementary video stream. Load this with ur AC3 into DVDLab and ur kewl.
