I've got a Sony TRV 27 miniDV camcorder. Had a terrible time getting it to capture. I've used VideoStudio 7, Scenalyzer, Pixela, ... all stop within 20 seconds or so. Swapped hardware, you name it.
Recently I tried DVIO and it captured just fine. I'm assuming I've got a capture driver problem. Can someone help me troubleshoot?
Thx,
Rich
Soyo Firedragon Motherboard
Intel 1.6 ghz
1 gb ram
2 40 gb 7500 rpm hdd
USB 2.0, Firewire
ATI 7500 dual monitors.
Not a full system restore. I downloaded the most current DirectX, Windows Media encoders, etc.
Another hint. When using VideoStudio, if I select AVI as the input type it switches over to DV. DV stops within almost instantly. Device is listed as Sony - MSDV. -
That's strange. I have the Sony TRV-25 (a similar model) and the software you mentionned works with my camcorder. Ulead VideoStudio 4.0 did not recognize it but version 7.0 did.
From the digital camcorder's menu, did you enable DV out?
I can't think of anything else. The drivers are only necessary for the USB connection. Anyways, they get installed when you install the Sony Pixela software.
You can also try DVapp (freeware capturing program) to see if it works.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 10:42 -
Best Captures for RF?
By therock003 in forum Capturing and VCRReplies: 10Last Post: 29th Jul 2008, 15:56 -
WMM recognzes camcorder but DVIO and WinDV don't?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Dec 2007, 05:34 -
WinDV or DVIO? Differences?
By w@ntonsoup in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Oct 2007, 16:51 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 21:04
