I just purchased a Toshiba SD-R5002 burner. I've copied 4 DVD movies so far (DEEP BLUE SEA, UNDERCOVER BROTHER, FRIDAY AFTER NEXT and NEW JACK CITY) using DVDXCOPY Express. I like that fact that I can make copies easily with only 2 mouse clicks. And the copies came out pretty good (I defrag my hard drive between the rip and the burn so that helps). My only complaint is that the ripped image file automatically deletes at the end of the burn so if I have an incomplete burn and I have it go through the entire rip/burn process all over again. Otherwise a fine program.
Results 1 to 12 of 12
you can go to the temp folder and copy/move the files so that you can save/edit them later
Defragging the hard drive every-time IMO is a bit of overkill.
I use the program a lot these days because I'm lazy and it does a fine job. -
I don't like this software... My primary language is french, but I also want the english track.. so I need french and english.. this software only rip 1 track.. stupid option.. anyway for 49$, you can have a lot better software
Depends on what criteria you use to determine "better". Certainly you won't find anything easier to use for $49. I haven't seen anything that gives better quality for $49.
Originally Posted by Bob W
I defrag before I burn a newly loaded audio file to CDs so it's just a force of habit with me. -
Originally Posted by BobK
DVDShrink 2.3 will also get the same result (or even better) and it's free -
Still a matter of your criteria for (and opinion of) what's"better". I've used Instant Copy and the result seems about the same. It's not easier to use- particularily if you want to do the movie only with no extras. And it's a certainly a lot slower.
I haven't used DVDShrink so don't know how fast and easy it is or what the result looks like. -
Since it's free, why not try it? IMO, the quality is on a par with IC -- up to ~6GB.
I would definetely use dvdshrink before i pay any amount of money for anything else. Shrink allows you to select your audio tracks and do a movie only or shrink the movie to make it fit on one dvdr, without any noticable pixelation...up to around 20%.
Try dvdshrink, i dont think you will be dissapointed, and its almost as easy as xpress.
I value your opinion.
By circanow73 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2010, 13:22 -
Slideshow Software Opinion?
By avguser in forum Newbie / General discussionsReplies: 10Last Post: 4th Jun 2010, 14:02 -
Your Opinion of Windows 7
By frieday in forum ComputerReplies: 31Last Post: 13th Jan 2010, 12:50 -
Laptop Opinion
By Poppa_Meth in forum ComputerReplies: 15Last Post: 7th Jun 2009, 11:16 -
Video Amplifier - What's Your opinion?
By therock003 in forum Newbie / General discussionsReplies: 17Last Post: 8th Jan 2009, 20:25
