I'd like to capture to MJPEG using an ATi AIW 128 (based on an ATi Bt829 video coder chip)
However I want to be able to use virtual dub without installing ATi's MMC (because it seems to take over the whole machine & also I've not found a version that works properly)
Problem is that I cannot increase the resolution above 352 by 288, the message "resolution not supported" gets returned.
Anyone know of a method of increasing capture resolution without MMC installed? A registry hack for example.
Paul N.
WDM or WDM-VFW bridge and standard BT capturing methods.
Gosh this was a blast from the past!
I found that all the updates from Ati wouldn't capture greater than NTSC 320 by 288 (which is pretty usless anyway as I'm PAL).
In the end I found the solution that worked was to install '98 & load the software from original CD.
This enabled all the higher capture settings. Its pretty poor of ATi to effectively drop theAiW128, but its not uncommon.
It was all a bit of an experiment anyway as I've moved onto the Hauppage PVR-USB2 for analogue caotures & the DEC2000 for TV capturing & dabble with the ATi when the mood takes me.
Thanks anyway guys.
PN
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 11:13 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
