Hi
I'm trying to copy a burned divx movie file from disc to my other pc. Half way through it gives me an error message that it can't read from the device...Games and audio files are no problem to copy and paste,,,only movie files give me this error....Am I doing something wrong with burning those files.(they are buned as dat files) Any help would be great!
tia
you're sure they're divx??? .dat files means it's VCD, not DIVX.Originally Posted by winner300
can you play the movie on your comp and standalone DVD player? -
HI
It's a Divx...I ment that I burned it as data file. The file plays on my pc with no problems...just the copiing part won't work. My dvd player doesn't support avi files...only mpeg.
Still haben't figured out how to get it on my pc...it does it with all my movie files...no problem with games or mp3s. I also tried it on my other pc and it won't do it either...
any ideas??
tia -
Sounds like it might be a media problem. The CD that the file is on may be to bad to copy from, but the Divx player may just skip the bad section when it's playing.
Try making another CD with the same file and see if the problem still exists.
Problems with turning image sequences into movie files for timelapse?
By adam-tl in forum MacReplies: 26Last Post: 2nd Dec 2011, 07:05 -
QT Pro and copy/paste .mp4
By rotuts in forum MacReplies: 3Last Post: 4th Sep 2010, 12:45 -
Problems Burning Movie Files onto blank Dvds-RW disks
By tealmarlin in forum Newbie / General discussionsReplies: 35Last Post: 1st Jan 2009, 12:18 -
Copy/Paste DVD to hard drive?
By jason in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2008, 15:35 -
windows installer pops up each time i paste or copy comething
By Rudyard in forum ComputerReplies: 4Last Post: 28th Jan 2008, 17:35
