Basically how do I encode an 2.35:1 anamorphic and keep it 2.35:1 anamorphic.Meaning, minus those grey bars.
Is there any encoding software out there that is specifically used for the creation of anamorphic dvd?
I usually use tmpgenc>DVDmaestro
I don't want to use the crop solution.
DVD's only support 16:9 anamorphic or 4:3.
This means there will be bars, but much smaller than what is normally seen on a 4:3 TV set. You cannot get rid of the bars completly without removing part of the side of the image.
So you want to take a 16:9 anamorphic DVD of a 2.35 movies and keep it 16:9.... yes?
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 10:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 16:46 -
anamorphic or dv pal 16:9
By Fking in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2008, 14:11 -
anamorphic or not anamorphic
By cd090580 in forum Video ConversionReplies: 3Last Post: 23rd Jun 2007, 13:48 -
Anamorphic --> 4:3 Ltbx?
By acs236 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 9th Jun 2007, 12:57
