Got a new system (barebones) and was wondering is there a best placement for the dvd-r burner. I heard they get rather hot.
Case: 3 - 5 1/4" Bays (will have another cdrw in one)
Thanks. I updated my computer profile, so it's current.
I know; don't laugh about the STB card (will be getting a Canopus) and you can console me about the dreaded Asus P4S8X (gold). It was too late when I found out about all the problems.![]()
Thanks in advance![]()
Never discourage anyone...who continually makes progress, no matter how slow.
Plato -
yes, there is alot of heat generated from the unit, try and place it in a bay with space above and below.
If you have a free bay, it might not be a bad idea to pick up a drive bay fan. The unit slips into a regular 5 1/2" bay and vents the heat out the front of the machine. Also helps with heat dissapation for the CPU and high end video cards.--
Will -
dvd burners come with a fan in the back..so should help with the cooling...
try to minimize the burner usage for strictly burning DVDs
that means..no DVD ripping or CD burning....why??? because DVD-ROMs can be used for DVD ripping 1) they rip much faster than DVD burners 2) they're much cheaper to replace when broken (i.e. $30 vs. $170+) also, CD-RWs should be used for burning CDs 1) they usually burn faster than DVD burners (40+X vs. 8X) 2) they're much cheaper to replace when broken ($20 vs. $170+)
Help with subtitle placement
By Mystic DUDE in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2011, 09:39 -
equipment placement and grounding
By smartel in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2011, 17:37 -
Thermal Probe Placement
By AuroEdge in forum ComputerReplies: 2Last Post: 10th Feb 2010, 08:19 -
Which SATA DVD Burner is best for QUAD System?
By mlong30 in forum DVD & Blu-ray WritersReplies: 20Last Post: 12th Sep 2009, 04:50 -
Speakers placement with tv, DVD player, etc (interferances?)
By DVinci in forum ComputerReplies: 6Last Post: 23rd Jul 2007, 19:50
