I got a few days ago a memorex label pack(matte) which came with a fantastic software "exPressit". You load the picture of your label (scanned), and the fuction "fit" lets you put it to the label template perfectly. Print it, done!
Now, I bought some glossy labels, but not a memorex brand (too expensive). The program doesn't allow to change the template. My new labels are compatible AVERY 5824/5931. I tried different programs (even Avery) but didn't find one that let me choose a compatible template with the "fit" function.
Does anybody know a good one that does both?:
Thanks a lot! :P
Is there not just a simple resize function that lets you drag the corners and sides of the image around so you can make it fit manually?
Downloading software question
By rosmari in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2010, 14:09 -
Epson print CD/Mac - photo editing for DVD label question??
By dvdguy24 in forum MediaReplies: 16Last Post: 20th Aug 2010, 04:51 -
Good lightscribe label software
By neworldman in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 12:48 -
CD/DVD - Label Printing - Picture Size Question...
By shotokan101 in forum Newbie / General discussionsReplies: 8Last Post: 9th Jul 2008, 18:18 -
Question about Recording software
By Me-Hostage in forum Capturing and VCRReplies: 2Last Post: 29th Jun 2007, 22:34
