Im trying to convert 640 x 480 PAL Divx to NTSC DVD - I a m using the guides on this site but am having trouble with seeing lines when there is any sudden movement in the video content. I am using vurtualdub to extract wav file then using tmpgenc to recode to mpg2. The video looks fine besides the lines that show up here and there. I have a feeling that I am not getting the framrate set right or something. Any help woudl be appreciated.
Results 1 to 9 of 9
why do you believe it to be PAL? is it 25fps?
Sounds like you are seeing interlace lines, this is either a -very- badly teleclined film or is pure interlaced video (most likely a TV series or very low budget film)
If you encode the file anyway, how does the output appear on the TV? are the interlace lines observable all the time, or do they come and go? -
I believe it is pal beause I looked at the file info and it says 25 fps. The interlace lines come and go (only when a there is a fast pan across the screen etc.) Thanks for your help.
its interlaced lines. it will look good on your tv.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Thats the problem - It doesn't look good on the tv, it looks good on the computer.
thanks! -
are you encoding it as interlaced, and are you telling TMPGEnc that the source is interlaced?
I am using non-interlaced settings for both just like it says to on this site's instructions - should I be doing it differently?
thanks for your help! -
Apply the deinterlace filter in VDub, then frameserve to TMPGEnc. I hope that works.....
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
Editing custom frame size video - portrait/vertical VGA - 480 x 640
By PMESKA in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2010, 06:02 -
FAVC Pal-Ntsc conversion question
By spiritgumm in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 10:12 -
sorry for yet another pal to ntsc conversion question relating high def.
By gearo in forum Video ConversionReplies: 2Last Post: 3rd Nov 2007, 22:20 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 12:25
