Hi,
I might've done something dumb about the settingsbut I don't get audio track with the rendered avi files. The manual says the audio track should automatically display with the video when we load it onto the project but I see only the video track.
Please someone shed a light?
TIA,
Dawg
most likely your audio is in a format that vegas can't handle like ac3. open your movie in goldwave and save the audio as wav
Thnx for your quick tip. Ain't it strange if it can't recognize the audio track from DV files. I'll try some other ways.
Dawg -
you did not say you were rendering dv before ... it should show no problem .. if you play it - do you hear it ?
I can hear audio on the original dv file but not on the rendered avi file. If I load the rendered onto the TMPGenc, it automatically picks up the audio track from the same source.
Dawg
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
Vegas 4 vs Vegas 8pro audio levels
By schematic2 in forum EditingReplies: 2Last Post: 19th Feb 2009, 20:57 -
Audio problem in Vegas
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 0Last Post: 11th Jul 2008, 18:06 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum Capturing and VCRReplies: 3Last Post: 29th May 2008, 08:22 -
Sony Vegas 6 Audio
By Sunshine3012 in forum DVD RippingReplies: 2Last Post: 25th Oct 2007, 22:32
