Can anyone tell me if there is any software to rip a(s)vcd that has been burnt on a disc back to a image bin cue file?? as i wanted to put it on dvd but I only know how to from a bin cue file. Cheers
Results 1 to 12 of 12
You can't burn svcd bin/cues on dvdrw. Or do you mean that you will use svcd2dvdmpg or some other tool to create a dvd?
You can use cdrwin,vcdeasy,fireburner to create bins/cue. -
Yes mate just wanted something to recreate the bin/cue files......any of the ones you sugested? or do you have a favorite??
simple ... copy the disk to your hdd using cdrwin from goldenhawk using the disk image/cuesheet setting it will be saved as cue/bin files
get cdrwin here
http://www.goldenhawk.com -
CDRWin is highly recommended for making CUE/BIN images of existing discs.
If you are willing to go with other image formats, however, I suggest that you use CloneCD.
Regards.Michael Tam
w: Morsels of Evidence -
Installed cdrwin but its telling me the aspi driver for cd rom is missing. Iv'e been to the web site to download it but the links not working
i'm useing windows xp pro........It's just i have a stack of films on (s)vcd and some are good enough to go on dvd any more ideas plz
If you just want the sequence-items (i.e., the video tracks), off a S/VCD, just use the CDXA2MPEG tool in GNU VCDImager Tools: http://www.michaeltam.com/vcdimager_tools.html on the "DAT/MPG" files on your (S)VCDs.
Otherwise, if you REALLY need CUE/BIN images for some reason, you could always go the convoluted way of using CloneCD to make a CloneCD image (CloneCD's ASPI drivers work with essentially everything), mount it with Daemon-Tools as a virtual CD, and then use CDRWin on the virtual CD...
Regards.Michael Tam
update your aspi driver from this site
http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&language=English+US...=aspi_v471.exe
or use the aspi drivers supplied with cdrwin, .. click "devices and settings" select the "aspi" tab and tick the second option "use aspi drivers installed by cdrwin (if any)". ...... you must have these installed to be able to use them if you did not install them at the time you originally installed cdrwin just reinstall it and tick yes when it asks if you want to install aspi drivers supplied with cdrwin -
Assuming that updating the ASPI drivers don't work, you can still use my aforementioned method (the default Adapatec drivers don't work with external drives I think).
Regards.Michael Tam
or make it simple on yourself. u can use Isobuster together with Ulead Movie factory to create a DVD from a SVCD:
1) Go here and if you dont have Isobuster you can download it at the top of the page: https://www.videohelp.com/forum/userguides/141726.php#svcdbin
and follow the instructions of the last example but remember you want only to extract the MPEG2 files.
2) Go here and if you dont have Movie factory, u can download here as well:
https://www.videohelp.com/vcddvdr.htm
follow the instructions and presto.
If u do consider doing this i highly rcommend that you go to your local disk (C drive) and create an empty folder so that when you follow the instructions of Isobuster you can put your files in there and not get mixed up.
what i did was i was trying to get 3 VCDs onto one DVD so i created one folder with three folders in it and i would keep the data from each VCD in each folder. but this is just my way, you might find a way that is easier.
IF YOU HAVE ANY QUESTIONS JUST SEND ME A PM @ skip2mylou AND TELL ME WHAT YOU NEED HELP WITH. -
Still no further cant get the aspi driver to go in keeps telling "The NTVDM cpu has encountered an illegal instruction" I have installed iso buster + movie factory but i'm still no wiser when iso buster is open i can see 3 folders in the vcd drive EXT MPEG2 and SVCD so how do you recreate the bin/cue files?
Firstly, you should explain why you need the CUE/BIN images in the first place. You may be trying to doing something the "hard way".
In any case, did you try the CloneCD --> Daemon-Tools --> CDRWin method? It almost always works as CloneCD has an EXCELLENT in built ASPI driver.
Regards.Michael Tam
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to rip the video from (S)VCD CDs or BIN/CUE images
By Baldrick in forum User guidesReplies: 45Last Post: 4th Aug 2010, 05:56 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
