  1. Dickuk
    Guest
    When trying to run the program I get the following :
    ############### New MPEG File ###############
    File: C:\Documents\test.mpg
    Horizontal Res: 0
    Audio SampleRate: 0
    ******** Demultipexing original mpg file
    ******** Resampling audio from 44.1 KHz to 48 KHz
    ******** Multipexing elementry streams
    The test.mpg file is ok as it runs in media player and is recognised by TMPEnc (the horizontal res and samplerate are correctly detected).
    I have the latest updates and have tried BeSweet V1.5B18 and 19.
    Any ideas are appreciated?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If you do right click "Mpeg Info..." on the file what output do you get?
  3. Guest
    When I right click the file in windows explorer, I have no MPEG info tab or page??
    I am just trying de-multiplexing the video/audio and then re-multiplexing it to see if that fixes it.
  4. Dickuk
    Guest
    Seems to be working now - maybe duff header?
    I will burn and see if the audio sync is still ok and let you know
    Thanks.
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Indeed. Good to see that you resolved it.
