    Apr 2003
    brisbane, australia
    if you have a video 352x240 can it be converted to 352x288 to fit tv screen??i have tried using a ulead movie factory template of 352x288 but nothing changes.
  2. Member Conquest10's Avatar
    Chicago, IL
    352x240 is ntsc vcd resolution. 352x288 is pal vcd resolution. theres not much difference visually.
    His name was MackemX
    Boulder, Colorado
    You can use TMPGEnc to convert 352x240 to 352x288. you will have to add boerders. letterbox style to compensate
    Apr 2003
    brisbane, australia
    what are borders letterbox style?
