Hi,
I am using Nero to burn a movie which is in two 55 min parts. When I try to add the file to the cd, first Nero says it is not in correct format. It gives me two options: encode file in correct format/leave file alone. I selected the first and it burnt but the movie was stretched and the quality was terrible. I choose the latter and it burnt with OK quality but was still stretched. The movie is 600by300 (approx.) therefore it should have those black lines at top and bottom. My question is how do i add those to the file so the movie is not stretched? It is in mpeg format.
If anyone needs more info to help, please ask. I hope I can get this problem fixed! I'm new to this.
Thanks in advance.
BL
Which encoder did you use?
What a source file is it?
What are the specs of the source file?
It itsn't a Nero problem, but you set an aspect ratio wrong. Well, Nero reports a non-correct format. 600x300 is an odd resolution even if the aspect ratio is set right.
By the way, this is not a authoring topic, if you expect as much as possible replies, post in the right forum, that would be "conversion" or "newbie"
<font size=-1>[ This Message was edited by: Truman on 2001-09-28 00:28:00 ]</font>
Playback of MPEG-2 movie burnt on a DVD stops after some time.
By ssukuru in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2010, 03:31 -
How to merge subtitle file with movie when it is being burnt ?
By dilanalex in forum SubtitleReplies: 3Last Post: 7th Apr 2009, 03:15 -
burnt dvd's freeze 3/4 through the movie
By sc0rpthir13en in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2008, 19:40 -
Display streatched vertically
By anindyanuri in forum Newbie / General discussionsReplies: 22Last Post: 29th Sep 2008, 11:49 -
[WMP11]- how to stretch the movie to remove the black bars?
By LuckY7 in forum Newbie / General discussionsReplies: 5Last Post: 26th Dec 2007, 12:44
