i have did everything as the guide with Vdub and tmpgenc to add the sub and when i get the frameserved file (the small dumbmy file) to tmpgenc and it opens just fine but when i hit the encode button the error pops up saying "divided by 0" and will not encode. plz help.
Results 1 to 21 of 21
what do you mean by running good. which file the small .vdr file wont open in tmpgenc. but the original movie plays fine ....
Not the dummy file. I mean the original video file.
Hello. -
the orginal file plays fine on all media player and any player.
Now are you going to; solve my problem or just ask the same questions? -
Don't get cute. My video files are okay, remember? Anyway, your Direst Show priority settings in TMPGEnc, are they set to be the highest of the priorities. Look in Options-->Environmental settings-->VFAPI
Hello. -
yes they are set to highest. and still no luck i tried it with lowest with no luck either.
And the subs, are they placed correctly on the original vdieo, or too low, or far off center?
Hello. -
well...in the guide there really wasn't a choice to change the subs...i think...i just followed the guide...but one thing is the tmpgenc can play the file in preview section but there is no audio and i see no subs. Is this normal?
but if i click out of the serving mode and the normal virtual dub comes up tmpgenc saids the format is unsupported.
ok i tried to use the frameserve with no subtitles, just the movie but still the tmpgenc still gives me the same error.
Yes, it is normal. One more thing. Blank out the audio input box on TMPGEnc to make sure you do not have a audio problem, and make sure your Direct Show priority is back at its highest, since you have adjusted it.well...in the guide there really wasn't a choice to change the subs...i think...i just followed the guide...but one thing is the tmpgenc can play the file in preview section but there is no audio and i see no subs. Is this normal?Hello.
ok this is weird now the tmpgenc will not even open the file anymore it saids that its unsupported.
ok nevermined it does open the file my bad.....
I dont think there s any audio problem just help me get it to encode. -
Have you selected a template in TMPGEnc, and is there any chance your source file may be corrupted?
Hello. -
when you encode it do you have to use a different audio source like .wav because when i do that it starts to encode....
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2012, 13:29 -
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 12:39 -
Adding subs to VOB?
By Jens Thomsen in forum ffmpegX general discussionReplies: 8Last Post: 19th Jan 2009, 19:05 -
Previewing and adding subs
By lucho89 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 08:28 -
Adding Subs
By Russo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 21:45
