I need help writing an avisynth script that will help me convert a file that is 480x576 to 720x480. Any help would be appreciated.
Thanks,
VC
This is so much fun!
The complexity I think he's referring to might be the aspect ratio and the widescreen matting bars... yeah?
- Gurm -
vcheese--
Here's a thread that might help.. i had the same question and DJRumpy goes into detail of how to resize on the 2nd page.. but read the whole thread, as it's quite informative..
https://www.videohelp.com/forum/viewtopic.php?t=164104 -
Perfect thread. Thanks for the reference. I will definitely save this link.Originally Posted by jbenj01
Yeah, Gurm you are right. My math skills suck, ive killed too many brain cells over the years.Originally Posted by Gurm
You people are so helpful
Thanks,
VCThis is so much fun! -
Increasing the resolution by that much will result in a very blurry image. If you are simply resizing this to comply with the DVD specification, than you would actually get a sharper image by decreasing your resolution to 352x480 rather than increase it.
Its generally not a good idea to increase resolution unless you have to. -
Thanks for the reply,
Originally Posted by adam
If I maximize the bitrate will I still get a blurred pic. I figured that since SVCD bitrates have been used that when i employ DVD bitrates it will prevent blurring.
And you're right I was only increasing to 720x480 in order to stick with dvd standards. The DVD's that i have burned before with 352x480 resolution resulted in unplayable video on my standalone player.This is so much fun! -
First of all, WEIRD PLAYER
Also, higher bitrates won't help at all since the bluriness comes in during the resize.
Resizing video resolution and video quality
By Timex in forum Video ConversionReplies: 13Last Post: 23rd Aug 2011, 23:08 -
How to Crop a 720x480 video to make it 320x240?
By alc112 in forum EditingReplies: 3Last Post: 11th Jan 2009, 00:42 -
Cropping a 720x480 Video to 320x320
By crash447 in forum Portable VideoReplies: 8Last Post: 18th Jun 2008, 02:22 -
Converting 720x480 16:9 video
By jpc82 in forum Video ConversionReplies: 7Last Post: 8th Mar 2008, 19:21 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
