Hello,
I only being making VCD for a month and have ran into a strange problem. I have some .avi files with subtitles on them. I am using Nero 5.5 and Roxio 6 to make my VCD, but when I encoded my .avi to mpeg, I lose the subtitles.
Why does Nero and Roxio strips the subtitles off, what can I do to encode my file to keep the subtitle on? An easy way please.
Thanks,
Chuck
are these subtitles a different file? if so, you will have to encode with the subtiitles. there is a guide on here that shows you how.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
No only the .avi file. I read all the form on subtitles most talked about the other file, but I only have .avi. So that why I posted the question.
Chuck -
they're hard coded onto the avi? maybe you are cropping them off?
Ok. I have found out that the only way I can see the subtitle is with VobSub, I didn't notice that these .avi turned on VobSub when I play them. So I guess that is why Nero and Roxio code the subtitles. So now how I get VodSub to hard encode the subtitle in the .avi do that I can encode them?
Chuck
add subtitles using AVI Demux problem
By pensioner in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2010, 03:12 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Problem with hardcoding subtitles on mac from AVI to DVD
By Ruskall in forum ffmpegX general discussionReplies: 3Last Post: 30th Jul 2008, 16:35 -
AVI overscan problem (subtitles cut off)
By 3lutz3toe in forum MacReplies: 1Last Post: 28th Apr 2008, 14:31 -
a problem with adding subtitles to avi file by autoGN
By 3l8x in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2007, 02:28
Chuck
