    Jul 2003
    Florida
    I have Pinnacle Studio 8 and I captured some video, edited in and encoded it. I then burned it (twice) to a DVD+RW and it works perfectly on my Standalone Toshibal DVD player. I take the same exact image/project and burn it to a DVD+R and it won't play on the same standalone recorder? The media I am using has worked in the past on my player, so I know it isn't the media. What else could it be?
    Thanks......!
    "Wanting people to listen, you can't just tap them on the shoulder anymore.
    You have to hit them with a sledgehammer,
    and then you'll notice you've got their strict attention."
    -John Doe in Se7en
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Try playing that DVD+R that you burned on another player. It could be that your plaer is very fussy. I bet it will play on another player. Usually the cheep players are the most compatable.
    Jul 2003
    Florida
    No dice............I put it in my PS2 and it didn't even load up.
    -John Doe in Se7en
    Dec 2002
    Texas USA
    Sorry, but the PS2 isn't a real player. It's known to be picky. Try another standalone.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  5. Burn with burning soft. (like Nero) and do not use PS8 for burning.
