Having a hard time getting SVCD2DVDMPG+ to make a workable DVD. I have followed all of the tutorials and still when I play the DVD on stand alone (Qwestar DV100 Think it is the same as an Apex) it will start like it is going to play but I get rotating lines on the screen of the TV like when a VCR is off track (Don't own a vcr any more).
first we have to figure out if it is the dvd or your player. To determent that you need to do 2 things:
1. play the dvd in your computer with a program like power dvd or windvd. If it gives the same problem then it is the dvd you've made. If that is the case come back here and we figure something out.
2. check the players list if it plays svcd-dvd. I checked for you player but it isn't listed. So maybe you can play the disc in another standalone player (of a friend) the is listed as playing svcd-dvd in the players list. If it plays in that player your player can't play svcd-dvd.
Yf -
plays fine on my pc, my girlfriends pc and my work's pc1. play the dvd in your computer with a program like power dvd or windvd. If it gives the same problem then it is the dvd you've made. If that is the case come back here and we figure something out
Found out alittle more more about my Standalone DVD player it is the same as an Oritron DVD100. Going to try a DVDr (been using DVDR+-W Disk for testing). and try it on someone else DVD Player.2. check the players list if it plays svcd-dvd. I checked for you player but it isn't listed. So maybe you can play the disc in another standalone player (of a friend) the is listed as playing svcd-dvd in the players list. If it plays in that player your player can't play svcd-dvd. -
You can stop try cause your player will not play svcd-dvd or vcd-dvd see the player list
I did have some luck getting it to play on my DVD player but after 15 minutes it froze up
then maybe got lucky cause others tried and failed.. and what i read about the player it isn't a player i would want to buy. maybe you should spend a few bucks more and buy something that is a bit better..
Looking at getting a new player soon, need to do some research on a few DVD players first before I go and buy another one. Might even get a new TV while I am looking.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
