I Use Adobe Premiere to capture and edit my videos. I just finished one of my projects and I exported it. It came out to about 6.4GB. I am in the process of putting it on a DVD and stuff, but while i was doing that i wanted to give some people data CD's of the movie. So my question is if anyone knows of a good convertor that will enable me to fit my video on a data CD (not a VCD) and still keep the qaulity up?
Results 1 to 13 of 13
TMPGEnc. Make sure you have a DV codec, though. Click here.
Hello. -
Actually, you can probably use the KDVD template for TMPGEnc from KVCD.net. I was ably to fit 1:40:33 of video onto about 1.1 GB.
Originally Posted by funkguy4
Also the template above is for progressive film source and if he has DV material it is interlaced material which requires higher bit rate anyway .
you could split the original files with v-dub or v-dub mod (quicker) into data dvd or cd sized pieces and burn them .. -
If you are happy with a data disc and are not worried about playing it on a stand alone DVD player, then DIVX or XVID is probrably your best bet. The only hurdle is making sure that the people you lend it to have the correct codec installed on their PC so they can play it ok.
Originally Posted by Carkey"Art is making something out of nothing and selling it." - Frank Zappa
There is a guide here
https://www.videohelp.com/avi2divx.htm -
I downloaded VirtualDub and when I tried to open one of my AVI files it said:
"Couldn't Locate Decompressor for format 'dvsd' (unknown)
VirtualDub requires a video for windows (VFW) compatible codec to decompress the video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
Is this because I dont have a DV codec? Because I downloaded one abd it didnt seem to work so im not really sure what to do. So if anyone knows that would be great
Converting DVDs to .avi files
By c_woodul in forum Video ConversionReplies: 7Last Post: 28th Nov 2011, 13:05 -
G4 Keeps Crashing When Converting avi Files to dv
By elsiejazz in forum MacReplies: 3Last Post: 22nd Jun 2009, 04:24 -
Converting mp4 files to avi files
By HartsVideo in forum AudioReplies: 1Last Post: 18th Jul 2008, 18:20 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 15:43 -
Multiple home video clips... One giant AVI->MPEG encode or break it up?
By binister in forum Video ConversionReplies: 1Last Post: 14th May 2008, 13:59
