Hi everyone.
I have three ( *.dat) archives copied from 3 VCDs. I want to make anlt one mpeg file (Joining the 3 dat files). How should I proceed? (the first *.dat file I just changed direcly the extension *.dat by *.mpeg and it works fine, but the 2 others files didnt and the TMPGEnc deosnt recognise them like mpeg files).
Thanks in advance.
VCD Gear can do this, as can VCD Easy (look under tools). Either program can be d/loaded either here (to the left under Tools) or from http://www.doom9.org
vcdeasy can change them back into mpegs. then use tmpgenc as usual to join them.
His name was MackemX
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 15:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 04:24
