  1. Nero 5.5 Freezes when loading avi and then stops responding
    tried adding nero aspi but no luck there either
    using win 98SE
    Pent III
    30Gb hard drive
    512Mb ram
    Have just bought windows upgrade XP, but have video's on hard drive that i would like to keep.
    Feeling very clueless now
    any suggestion appreaciated.
    Apr 2002
    The State of Frustration
    Try to encode the video before giving it to Nero. An encoder like TMPGEnc may work for you.
    Hello.
  3. tried
    everything worked fine
    used
    tmpegnc to encode
    tmpegdvd to make ifo and vob files
    sent to nero, burn went fine
    went to play disc in sampro dvd player (work horse plays everything) it loaded and stopped.
    tried it in my memorex still didn't play
    on a whim i tried to play it on my computer using windvd and it loaded and stopped
    am i missing a step here?
    using dvd-rw media could this be the cause?
    or am i really missing a vital step?
    any help?????
    Apr 2002
    What setting in TMPGEnc did you use?
    Hello.
    Apr 2002
    Have you scanned the AVI for bad frames with Virtual Dub?
    Hello.
  6. Could be your media. You can try burning onto a DVD-R and testing.
    Also, drop your VOBs into DVD2AVI. Save a project file or just scan through and see if they all look and play fine.
