I am trying to make a VCD backup copy of Monsters Inc, but am having playback problems. This is the second time I have started from scratch with this project and have ended up with a bad VCD.
I have made several other VCD's using this same process (DVD Decrypter, DVD2AVI, TMPGEnc, Nero) that play fine, but the difference with this time is that I'm using VCD Easy to create chapters and interactivity, and then burning with Nero.
My question is: Are there any known issues with either Monsters Inc, VCD Easy chapters and interactivity, or Nero that might at least point me in the right direction to understand where the problem may lie?
I'm a little perplexed.
Thanks,
Tim
Oh, sorry.. guess I should state the symptoms...
VCD will play fine for awhile and then it just freezes. Both audio and video stop and it literally locks up my DVD player (Panasonic). I have to power down and back on to even eject the VCD.
I am creating and burning using the NTSC VCD template in TMPGEnc... no VBR or trying to squeeze onto one disc, or anything like that. This is a 100% compliant VCD to the best of my knowledge.
Tim -
does it play on your computer fine??
how fast did you burn it...try limiting to 4x max and c if that helps.
Freezing & skipping issue during playback
By Zumeraga in forum Video Streaming DownloadingReplies: 2Last Post: 4th Dec 2010, 18:55 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55 -
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 21:55 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 17:36
