Hi
I have an .mpg file that is encoded as a PAL SVCD.
I have a copy of Nero 5.5.1.8 with SVCD Plugin Version 1.3.
I have followed the exact instructions on this website on how to copy with Nero (even at 2X) but it just wont work.
My Sony DVD Player does play SVCD's normally, but not when I burn them. It throws up error message 'cannot play disk'
My PC DVD-ROM/CD WRITER doesn't recognise the disk either.
The .mpg plays fine on Media Player/WinDVD/PowerDVD
I have tried re-encoding (althought it is correct) with both Canopus Pro-Coder and CCE.
Anyone got any thoughts on where I could be going wrong![]()
Results 1 to 19 of 19
Originally Posted by yoz
I only ask because I see it is your first post, and I remember that I started off thinking why not do everything in PAL for the higher resolution.
If you are experienced, don't take offense."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
I have used the 'how to author a SVCD with Nero' URL: https://www.videohelp.com/nerosvcd.htm
For info on burning
My DVD Player is PAL but my PC don't recognise the CD Either. -
I have also tried burning a separate .bin .cue file using Nero and that doesn't work either.
This is the first time I have attempted to burn an .mpg.
Is there somehting basic that I am forgetting to set up correctly on my PC, or with Nero?
I don't suppose my CD Writer will make a difference, but just incase I'll let you know it's a Mitsumi 4802TE.
Keep the posts coming as I really stuck -
did you check your player at the dvd player compatibility section?
https://www.videohelp.com/dvdplayers
perhaps, it can play SVCDs, but requires the VCD header trick....heard some sony's only played SVCDs this way. -
Originally Posted by poopyhead
My firend's DVD Player will not play my burned SVCD either.
However I think this is missing the point slightly as my PC will not even recognise my burned SVCD either.
Any new ideas -
Can You see any files on the burned CD?
IF NO, You need to REPLACE the CD BURNING APPLICATION
Try Easy CD Creator 5 or Higher or
Easy VCD if your drive supports it
If you can see files..DRAG the one in the MPEGAV folder to an open POWER DVD window to see if the file will play -
Originally Posted by dcsos
I'll try Easy CD and let you know the outcome.
But why won't Nero work, I have a version that supports SVCD's and the SVCD Pluggin?
Has anyone else had a problem with Nero -
Under 98se
I had this problem with a MITSUMI burner
The shitty NTI CD MAKER bundled with it couldn't burn a cd either.
Someday I predict you'll be able to use nero..
But get it working with something else first..Then you can come back
to making NERO work..
Like once you get another program working
try uninstalling NERO 5xxx
and trying a fresh NERO 6
So try B's RECORDER too
or maybe
STOMP
also try this to update your aspi layer
http://www.adaptec.com/worldwide/support/drivers_by_product.html?sess=no&language=Engl...s+ASPI+Package -
I don't understand the above as Nero works with my drive for all other audio and data files
I get back to you on using Easy CD Creator though. -
but make sure to FINALIZE the disc...that's an option on the burn tab in nero's SVCD template. -
Hi
I have left Nero on my PC and installed VCD Easy V1.6 (400MB limit) aswell, I haven't tried Easy CD Creator Yet.
I have successfully burned an SVCD onto the same CDRW I was using with Nero. This plays both on my PC and on my DVD player. Also VCD Easy is using the same ASPI drivers as Nero is using, therfore the ASPI problem is eliminated.
Any thoughts on Nero as that is what software I would like to use ideally, because of the 400MB limit on VCD Easy. By the way the finalise CD option is checked. -
I'm pretty sure standard SVCD is supposed to be Mode 1 so you can get 800Mb/disc. Last I checked, nero uses mode 2 for SVCd (no klew why). Even so, I don't see why your computer wouldn't recognize the disc unless you overburned and it was too glitchy.
mode 2 not mode 1.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
errr....
mode 1 is for audio and data = 700 MB/80 min
mode 2 is for (S)VCD = 800 MB
plz get it straight -
This is now sorted.
I updated my version of Nero from 5.5.8.1 to 5.5.10.15.
I have burned a 4 minute SVCD and it works both on my PC and standalone DVD player.
Adios Amigos
REALLY STRANGE RARE THING: MPG video CHANGED after file transfer or copy
By xboxsold in forum Newbie / General discussionsReplies: 21Last Post: 1st Feb 2011, 09:28 -
getting MediaCoder to copy audio during mkv to mpg encode?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 15th Dec 2010, 02:47 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 16:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
