I need to use VirtualDub's frameserve to CCE, and I have a question about that.
Is it possible, and is it practical, to use the VFAPI Converter to convert the frameserve VDR file to an AVI file, then encode the AVI file with CCE?
If that's possible, I can do a few frameserves, convert each one, then do a batch encoding with CCE.
Thanks,
Dale
yes, but you'd have to keep VD frameserving the vdr files.
If you need to do multiple frameservers, Id suggest learning AVISynth.
AVISynth does frameserver, but you dont have to have a programming running to do the frameserving, so it makes doing batch encoding easy. It will also use VD filters.
I do this when I convert Stargate episodes, since I'm usally encoding a batch of 5 episodes at a time.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 06:01
