I'm about to get a Datavideo DAC-100. I thought Firewire cables were restricted to 15 feet. I was going to get a couple Firewire repeaters. But I've seen some vendors selling cables much longer than 15 feet. So I'm confused about whether I need the repeaters or if I can just get a long cable.
Results 1 to 11 of 11
According to the standard, the maximum cable length between devices is 15 feet.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
But that is for maintaining signal integrity at full FireWire speeds (~400Mbps). You will be transfering data at a much slower rate. I haven't done it, but I suspect that you wouldn't have any problems (cables are cheap compared to repeaters). Just get the length that you want and experiment.
How long do you need?ICBM target coordinates:
these cables work out to 32 feet at least at full speed with no problems at all
http://www.granitedigital.com/catalog/pg18_firewirecables.htm -
That's a good point about the speed. The long cables I've seen specifically mention that they are for DV use, which would not be full speed. As you say, cable are less expensive than repeaters, which is why I want to go that route if I can.Originally Posted by SLK001
Thanks for the feedback. -
Just because the maximum given length is 15 ft, doesn't mean it's the definate length. It will probably work at 20 ft no problem, or even 30 ft. Would also depend on the quality and shielding of the cable.
Chazzie -
as i said above -- i am using one of the 32 foot fire wire cables .. it is attached to a raid box ...
the cables i posted above work perfectly well at32 feet -- but i cant speak of others ..
they also are more money with heavy construction and filters built in -
This place has pretty good prices on cables, has them in lengths up to 20 meters (66') and claims "secure safe operation of our Firewire cable lengths up to 10 meters (33')".
http://www.unibrain.com/1394_products/cables/cables.htm
What firewire cable do I need?
By Jedi5 in forum MacReplies: 3Last Post: 7th Sep 2011, 17:17 -
Help with long VGA cable
By bud79 in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2010, 15:34 -
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 13:28 -
firewire cable required
By rizvi in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Mar 2009, 07:14 -
Ipod firewire cable?
By budz in forum Portable VideoReplies: 0Last Post: 27th Nov 2007, 21:22
