Ok I have captured a VHS that I made.
The result file is a 6.5Gb file for 2 hours (a bit too much but not a problem)
the capture is 720 x 540 with audio of 384kbs.
My question is, which software do I need to improve the video quality (the vhs wasn't great) and how can I improve the sound ? and maybe cropping a bit the video.
How to remastering a Mpeg 2 files ?
It depends on what it is (anime, old film, newer film). Sometimes you can adjust the colors, or the BEST thing to do is run it through VirtualDub, and first download tons of filters from other people, add them all together and then reencode it!
it's an home made Video made few year ago.. still was recoded on a DV, but I only have the VHS version.
I would need to ajust the color, brightness, contrast and remove some noise if possible
Blu-ray 3d remaster with audio change
By cinique in forum Authoring (Blu-ray)Replies: 2Last Post: 14th May 2011, 08:39 -
Hola! Remaster video. What software do they/you use?
By clintdiamante in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2010, 14:06 -
i need help to remaster my old vhs tapes to dvd quality(for mac or windows)
By ultimate15red in forum EditingReplies: 2Last Post: 12th Nov 2009, 06:13 -
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 15:46 -
Can I capture while encoding a different file?
By tygger in forum Newbie / General discussionsReplies: 12Last Post: 22nd Jun 2007, 21:09
