Hello. I'm having promblems fixing audio sync. Well, I thought I fix it. I have this movie that through the whole movie it was off sync. then I was able to fixed the last half of the movie. But not the first part. What is it that you do now. On what part of the movie do you start to fix it. Or do I have to encode it again then will it fixed by itself. LMK Thanks.
Sounds like you may have had bad frames. Did you check that yet?
Hello.
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 01:03 -
Fixing An Audio Track?
By Prince Valiant in forum AudioReplies: 5Last Post: 5th Feb 2011, 19:40 -
Need help in fixing audio delay which builds up as the video goes on ..
By ahmadka in forum AudioReplies: 4Last Post: 29th Jun 2010, 09:56 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 10:59 -
Fixing AVI Audio - modular distortion?
By 00Billy in forum AudioReplies: 1Last Post: 3rd Nov 2008, 09:27
