I've captured a movie (SAC) from my VHS tape collection at 720x480 and 4.0mbs, and proper audio settings into mpg, Using an ATI AIW 7500 Radeon, using the above ATI settings, Then i've demuxed it in TMPeg into an audio and video stream. Then authored it in DVD-Lab, then I started the compile routine in DVD-LAB, it's at this point that i run into a problem, about 10 minutes into the compile routine it shuts down and says that the video stream isn't simple , demux it and stops compiling.
I've demuxed the video within DVD-LAB and the same problem occurs. I've transfered several other movies using the above settings or with a resolution of 352x480 and have had no problems until this movie. Could this be a result of macrovision?
Gimmie a diaper and call me Sue if it is Macrovision!
It is probably something with the captured file. (Analog video can be very suspicious when transferred to digital format)
Chazzie
ffmpegX mpeg2enc compiling problem
By dubis in forum MacReplies: 5Last Post: 12th Sep 2008, 16:54 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31 -
Compiling a DVD
By LiCal in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 13:31 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 18:39 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 14:58
