When I capture in Virtualdub, I also use vdub to edit out the commercials and run dynamic noise reduction. Normally I just frameserve to TMPGenc but I haven't been satisfied with the quality lately, not to mention speed. I want to frameserve to cce, but when I select the .vdr file nothing happens. I don't want to just make another copy of the avi without commercials and with noise reduction, because then I lose quality too.
Any Help is appreciated.
It's a toughie, but first install AVISynth.
Then, go to notepad and make a file that says
AVISource("C:/blah.vdr")
Then save it as ending with .avs
Where C is the disc drice it's in, and blah.vdr is your frameserve file.
Usually it will work then, but there isn't a really clear way to do this.
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 23:46 -
Frameserve from VirtualDub64 to CCE
By pchan in forum Video ConversionReplies: 5Last Post: 11th Feb 2012, 07:23 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 13:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 07:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 06:41
