Well its "Video" related........
Ok, when it comes to video cards, i know little.
My computer came with ATI 9000 Pro and with the introduction of the 9800 pro ( http://mirror.ati.com/products/radeon9800/radeon9800prome/index.html )I figure 128 megs will ROCK!
I also see there is a 128 meg Nvidia card ( http://www.macmall.com/macmall/shop/detail.asp?dpno=974941 ) which is about the same price.
So my question is......... Do I have to get a "mac edition" of this card?
Ive seen it for 1/2 the price in the PC version of this card.
Any chance that will work? Or do i have to get the "mac edition" of the card?
clueless on this stuff.
If you get a PC card you have to make sure that you can flash it so it'll work with the PPC chipset. I'd check http://www.xlr8yourmac.com/ first to see what others have done and suggest.
If memory serves (which you can't count on), you need a PC to perform the flashing operation w/ the Mac firmware. Also, it will void the warranty if something should go wrong. So, it could be cheaper if all goes well, or it could be more expensive if it doesn't work, and you've just destroyed a perfectly good video card. You might find it easier and safer to just get a Mac version, and have support if anything goes wrong.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I agree!
got a few on ebay im "watching"
128 megs for video should be REAL nice
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 03:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum Capturing and VCRReplies: 14Last Post: 18th Jan 2008, 22:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
