Hi,
I have just tried to join 2 avi files using virtualdub, but when i try i get the following message;
"Cannot append segment: The audio streams have different sampling rates - 16864.00000 x 16865.00000"
It is 1 movie split into 2 parts.
Does anyone know how i can change so they both have same sampling rate please?
Thanks in advanced
TheDJ®
Results 1 to 27 of 27
Someone may have a better way but here's mine:
1. Extract a wav file from each segment, I use Goldwave.
2. Import the wav file back into each segment and save using Vdub.
3. Join the files.
If you need more details just ask. 8)"Art is making something out of nothing and selling it." - Frank Zappa -
Hi Zippy, thx for the reply!
Sounds good, but i have never imported a wav into a film before using VD, could u please give me some instructions plz. Extracting the wav is not a problem.
Look forwards to your reply.
TheDJ® -
Open the file in Vdub, under audio>wav audio and select the wav file created earlier. Set both audio and video to direct stream copy. Under file>save avi.Originally Posted by ZippyP.
Do that for both parts and you should have compatible files for appending.
Good luck!
If the AVI files are consecutive, you can open teh first one, and append the second one. Then, do fuill processing mode in audio tab, File -> Save WAV. Then, Audio -> WAV Audio. Load your WAV file. This should be one long video/audio stream made from your 2 source AVIs an the decompressed audio. FRAMESERVE AND GO!
That would work except for the following problem:Originally Posted by funkguy4
8)Originally Posted by TheDJ®"Art is making something out of nothing and selling it." - Frank Zappa -
Hmmmmmmmmm................yes, sounds plausible. :P Meh, it going to suck for u..............
resample the audio in each file so its at a constant bitrate.
set video->direct stream copy
set audio->full processing mode
set audio->compression->mp3 128kbit/s or whatever.
hit save as.... then save it as like.. NewAVI1.avi
do the same for the second half, then try and combine the NewAVI halves.
im sure there's an easier way to do this, but.. converting the audio only takes like 3 minutes (for me at least) so it's just as quick.poop. -
Ching, this is kinda off topic, but the audio conversion is more hard drive intensive than anything else, so it'll be like 3 minutes for most ppl. MINE TAKES 2.5 MINUTES!
Thx for all the replies peeps, appreciate it.
I tried saving the avi with seperate Wav audio, and avi size doubled when finished saving!
So then i tried resaving the file and compressing the audio with MP3, but highest rate i could get on VD was 56kBits/s, 24kHz, Stereo. Would have thought 128, 48 , stereo would have been available?!? I did click show all formats also.
Not sure wot else to do... -
thx for reply.
I'm a bit new to this, so not sure where to get lame mp3 and how would i insert it to show in VD? -
http://www.softnews.ro/public/cat/11/1/2/11-1-2-70.shtml
Just install it.....:P -
thx for the site!
I opened the zip, there is no installation file? just data....where do i put it plz?
thx -
Actually, sorry for being so screwy, but my copy got installed with the Nimo Codec pack. DO NOT INSTALL THE 2 CONFLICTING AUDIO CODECS AS THEY WILL MESS UP YOUR SYSTEM AS MINE WAS!
Here's a link:
Bunch of Nimo mirrors -
I think TFM. I don't know if it still exists with the new version of Nimo tho......ask someone who knows....
hmmm....i have tried nimo on my PC before, and it didnt like it for some reason...
....some video files wasnt playing and sound was cutting out......cant i just install the lame audio straight into VD folder?
I have just found the Lame MP3 on my PC. It is already installed and being used by a cd ripper prog called EAC. why isnt it showing in VD?
Lame can be installed as either an ACM or a DLL. Yours is probably installed as a DLL, so you still need to install it from Nimo.
Lame MP3 codec installed, showed up in VD, i selected 128k, stereo.
When trying to resave avi, i get the following Error message:
"Audio Compression Manager (ACM) failure on compress"
I dont seem to be having much luck with this, dont know wots going on here?!??!
I tried with source audio aswell as seperate wav audio, same error!
never used goldwave....any chance of a link and some instructions plz
thx -
Actually, just go get BeSweet with the BeSweet GUI. You'll understand tha, and (hopefully) everyone know show/where to get BeSweet. If you don't, just google it.
ok thx for reply.
I have got the BesweetGUI, but have no clue on how to use it??
can u give me a few instructions plz.
thx -
Click BeSweet. Since you're kinda noobly (sry) at this, just pick one of the DSPGuru Profiles at the top right. Then, Click 2LAME at the right middle (in the bunch o' buttons area) and change the bitrate as needed.
Problem with samsung dvd writer .. plz help!!
By jukaragz in forum DVD & Blu-ray WritersReplies: 7Last Post: 28th Sep 2010, 15:49 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 23:25 -
Problem: LG HT302SD Home Theater does not show VobSub subtitles.. plz help
By eng_asa in forum SubtitleReplies: 2Last Post: 8th Oct 2008, 02:41 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Windows Movie Maker Problem PLZ HELP
By akenny01 in forum EditingReplies: 2Last Post: 27th Feb 2008, 15:44
