  1. The "STILL PICTURES" option in DVDShrink allow me to compress all the extras on my DVD-9 backups to the point where I barely have to compress the main movie (great space saver). I was wondering if this option messes up the chapter listings or IFO crap that InstantCopy does when you strip extras. InstantCopy produces DVD-9 converts that do not play well on my Sony 715 (newer one) and DVDShrink produces DVD-9 converts that play fine on the Sony.
    DVDShrink simply seems to be too good to be true...
    What are the catches?
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I compress extras down to still frame and turn off their audio. Then reencode the movie with as little compression as possible. Its never messed up my chapters that I noticed and works great.
  3. Hmm, dump ze' audio, never thought of that.
    The audio is messed up anyway when you get still frames cuz it's full audio with 1/10th the animation!
    Good idea wise DVDShrink user.
  4. I go one step further -- I use Menuedit and disable the menu items that lead to extras/episodes that I have turned into Stills. You can't make a mistake that way and select things that don't work.
    Also, I read recently here were someone took the Shrink files and then reshrunk them -- this was to get the 80% reduction of the still files down even further. Sounded clever to me -- you just either don't compress the movie in the first place, or don't compress it again (in my case I never compress a movie anyway).
    "Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
  5. Very few that I've found so far... use it almost all the time
  6. Originally Posted by SyndicateFoo
    Humm, that's surprising. I've just used "Still Pictures" on the end-credits of "Traffic" and the audio is fine.
    (I've used "Still Pictures" instead of cropping them off specifically because of the soundtrack I wanted to keep. )
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  7. Forget the extras and menus, just use the reauthor feature so you can minimize the compression and don't have to worry about the layer switch issue either.
