Yo, folks!
Here is my problem. Using bitrate calc [dvdrhelp.com/calc] I can find correct bitrate for my SVCDs. But "SVCD Max Bitrate" tag contains higher value than TMPGEnc can accept (namely 2520 kbps). This Happens when I choose Audio bitrate smaller than 224 kbps. And it causes that not full volume of SVCD disc is used (file can be 50-100 MB greater and it still can fit onto CD-R 80).
Is there any formula how can I safely rise Bitrate when SVCD Maxbitrate is greater than 2520 kbps? I mean some ratio constant (I suppose I will need to calculate it for every movie, but it's O.K. to me...) or whatever.
Every suggestion will be highly appreciated. Bitrate is life & space should be used!
If I was not clear enough, just write here and I will elaborate deeper.
THANX
-=SWooP=-
Kill one - you are murderer.
Kill many - you are conqueror!
Kill 'em all - you are GOD!!! -
Some DVD players will have problems playing discs with a bitrate much above 2520kbps, others will play them ok. You will have to experiment. Load the unlock template you should then be able to increase the bitrate futher.
Craig:
Tnx. But my idea is, that summation of video and audio bitrate must not exceed some value. Hence if I choose smaller audio bitrate then I can (accodringly) increase max video bitrate. Something like TMPGEnc Illegal VideoCD template...
-=SWooP=-Kill one - you are murderer.
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 13:06 -
TmpGenc Authoring Works 4 - how to set bitrate?
By mrhata in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2009, 00:40 -
TMPGEnc Xpress bitrate calculations are off
By Taeran in forum Video ConversionReplies: 3Last Post: 24th Sep 2008, 17:17 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 18:49 -
ISO advice on what bitrate I should use in TMPGEnc....
By RKelly in forum Video ConversionReplies: 4Last Post: 26th Jul 2007, 12:13
