I want to convert a movie in Ulead Video Studio 6 and keep the full screen aspect ratio, i have used Tmpgenc and it has an option "Fullscreen(keep aspect ratio)" ... how can i do this in Ulead Video Studio??? Whenever i try to set the keep aspect ratio in Uleads preferences, it does nothing, i think this option is only for inserting images.. and still squishes the movie, i have read that it only looks like that on the comp but it still is squished im my dvdplayer, I want the black bars on the top and bottom as they are in the divx file im trying to convert to SVCD...please help!!!![]()
Don't know if this answers your question but...
One thing I learned that was helpful was to go into project settings BEFORE you start each new project and set it for what you need ie: ntsc or pal and dimensions, etc. Otherwise it tends to default to one or the other and shows the previews, etc, at the wrong dimensions.
You can change a project's properties while you are working in it - a screen will pop-up warning that displays, etc are changing and you just accept those changes.
Hope that helps. Good luck. -
I think I have tried this but, will try it it again, thanks for the reply..more input requested if anyone has any please.
P.S. why is there no Ulead Video Studio 6 Guide on this site, does anyone know where I can find more info on this product? Uleads Website does not give me much help.
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 08:57 -
"display aspect ratio" changes by itself after remuxing .mkv vide
By roise_r in forum Video ConversionReplies: 5Last Post: 2nd Sep 2009, 02:35 -
Ulead Video studio 10 "create DVD"
By kiethpenny in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2009, 17:40 -
Ulead Video Studio SE 9 Crashes on "Create Disc"
By Canopus Smoker in forum Newbie / General discussionsReplies: 6Last Post: 29th Nov 2008, 17:46
