  1. Hi ,
    I seem to have a very weird problem latly . I am not able to extract mpg's from cd images anymore . It says there are errors and then if i say - ignore all - i get a 0 kb file .
    When i try to load an mpeg in TmpgEnc - it says it is not supported .
    On the other hand it works if i load the image with the deamon tools and then use TmpgEnc . Anybody has any experience with this ?
    Before i forget - Mpg's still play fine though ...
    Oh and i hope this is the right forum for this kind of questions ...
    Dec 2002
    Texas USA
    Reinstall.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
    Feb 2002
    nyc
    choose" extract but filter mf2g" . whne you extract am mpeg 1 you'll have to rename and add a".mpg"
    bloo
  4. I was having the same problem the other day when I was extracting the mpg and it was 0mb, realised that the disc was faulty.
    Maybe that is your problem ?
    If it's wet, drink it
    My DVD Collection
  5. I tried reinstalling IsoBuster - but that didnt do the trick .
    I tried it with several svcd images - and none worked . Strange thing is that TmpegEnc and Author doesnt want to take them anymore .
